I'm experiencing a weird electrical problem. Since I don't know anything about electrics, it's a real problem. Ok, here it is: I am continually blowing two fuses and one relay. I thought all this had to do with a bad kill switch or a bad electric petcock, but I think not. The fuses are the 30 amp battery fuse and the 5 amp signal fuse. At the same time I lose my relay that controls my horn and brake lights.
I suppose this is some sort of grounding gremlin?? I am looking for exposed wires, but I haven't seen any.
Any thoughts on this would be appreciated. I did see that my Power Commander has a large metal plug that is just bouncing around under the seat and possibly touching the frame. Could this be it?
Enzo
GEI relay is in my opinion a neccessity.
I just blew my 30A fuse the weekend before last.
Not sure why :huh2:
I think I'll order a full set of GEI relays just to eliminate potential problems.
Maybe your battery is getting old and weak and the charging has to work harder??????
