Guest scooterneal Posted July 24, 2006 Posted July 24, 2006 Noticed a leak in my oil delivery line. Is this normal wear or is it caused by pressure problems? It's a 2000 Basa w/ 22,000 miles on it.
jrt Posted July 24, 2006 Posted July 24, 2006 I don't know how the Bassa oil lines are constructed, but I've replaced all my old-style cloth covered lines with either hard-piped steel (from the Eldorado) or use the stainless steel braided line. The fittings seem to leak on the cloth-covered stuff. Be sure an use all new crush washers (6 of them) when you install new ones. If you careful, you can put a *very small amount* of teflon sealant on the fastener threads (not tape- use the liquid stuff).
