I'm ISO a Guzzi part number and a likely USA source for the external fuel pump, Piersburg 02T077, 7.21287.03, for an early '03 V11S.
I expect Guzzi to want my first born son in payment, so I'm looking into a generic replacement as well.
Thanks,
Troy
Thanks,
Troy
Guzzi p/n 01107231
msrp $388.00 usd
PM sent
Guzzi p/n 01107231
msrp $388.00 usd
PM sent
Todd, Thanks for the prompt reply.
My Piersburg pump developed a short. I cut the aluminum can with a pipe cutter at 7/8" from the output end of the pump and it came apart with no damage to the components. This thing is a work of art on the inside. If I can clear the short I might try to seal it up and use it again. I think Piersburg makes good stuff and I just got unlucky. However, they warn against running the pump dry, which I'm prone to do when I forget to open the petcock.
Best regards,
Troy
