dangerous Posted July 30, 2006 Share Posted July 30, 2006 04 V11 not a year old yet and the neautral light is often not comming on in neautral, which means as soon as the side stand goes down, it cuts the engine. Ideas please on what the problem might be, and has this happened to anyone else? Link to comment Share on other sites More sharing options...
canada goose Posted July 30, 2006 Share Posted July 30, 2006 04 V11 not a year old yet and the neautral light is often not comming on in neautral, which means as soon as the side stand goes down, it cuts the engine. Ideas please on what the problem might be, and has this happened to anyone else? Yes.......don't know what problem is..............disabled sidestand switch.........end of problem. Ken Link to comment Share on other sites More sharing options...
Martin Barrett Posted July 30, 2006 Share Posted July 30, 2006 04 V11 not a year old yet and the neautral light is often not comming on in neautral, which means as soon as the side stand goes down, it cuts the engine. Ideas please on what the problem might be, and has this happened to anyone else? If the light is not coming on would indicate that the neutral indicater switch has failed - mine was changed under warranty - I think someone did clean theirs up. Its not an uncomon problem - try search :!: ask Dr Gill about the advisablity of removing the side stand cut out switch ( NB was removed by previous owner) Link to comment Share on other sites More sharing options...
docc Posted July 30, 2006 Share Posted July 30, 2006 Simplest thing is to check the connector at the neutral switch behind the starter. They often get loose or dirty. Next check, wiggle, clean or change the middle relay. Link to comment Share on other sites More sharing options...
dangerous Posted August 1, 2006 Author Share Posted August 1, 2006 thanks guys, as soon as I'm able to get to the bike (surounded by race bikes) Ill check out that wiring, sounds about right Link to comment Share on other sites More sharing options...
