dlaing Posted November 12, 2006 Author Posted November 12, 2006 luhbo said: One question BTW: why do some of you that are able to do so lower the max. RPM limiter value? Why don't you go up to 9000 instead, just for safety reasons for instance? Hubert yes, just for safety reasons. I have no need to go over 8000RPM so I set it to something just above 8000. If I get sloppy on my gear selection, I suppose I could still over rev coming out of a turn, triggering the cutoff. But it has not happened yet. I guess I should not be afraid to test it, but I just won't go into the red on the Veglia tach....probably an old habit from the days of no over-rev protection. But testing it will make me better prepared for the engine stalling or whatever it does when one hits the cutoff rpm. Maybe I'll set it to 7500/7700 RPM just to test it where I feel more comfortable.
motoguzznix Posted November 13, 2006 Posted November 13, 2006 luhbo said: The reason for 44° spark advance is that it can be favourably done on modern engines with modern engine management. Such high advances would be advantageous also for older, points equipped engines, of course. The only problem was, you couldn't go back when and where in the map it was required. So some safety distance had to be kept. That's all. One question BTW: why do some of you that are able to do so lower the max. RPM limiter value? Why don't you go up to 9000 instead, just for safety reasons for instance? Hubert Hubert you made a good point about the spark advance. On your priviously quoted spark map, the advance is no more than 35° at the WOT line too. Concerning the lowered rpm limit: If you look at the stock power curves, the max power is always at 8000 or above. The biggest gains caused by the remapping were in the 5 to 8k rpm area. Max power is now around 7000 rpm. This convinced me to lower the rpm limit as the engine wear increases with the climbing engine speed. And some more safety when doing the dyno runs is welcome too.
luhbo Posted November 13, 2006 Posted November 13, 2006 motoguzznix said: .... Max power is now around 7000 rpm. This convinced me to lower the rpm limit as the engine wear increases with the climbing engine speed. And some more safety when doing the dyno runs is welcome too. This is true, but having the limiter at 9000 doesn't mean you'll have to use it. If I go to 8300 I also may want even more in some situation, why should I pass on that? Hubert
dlaing Posted November 14, 2006 Author Posted November 14, 2006 luhbo said: This is true, but having the limiter at 9000 doesn't mean you'll have to use it. If I go to 8300 I also may want even more in some situation, why should I pass on that? Hubert Beware the straw that broke the camel's back I'll bet if I set my throttle to never open past 50% and the RPMs to never go over 5000rpm my engine would last twice as long...mostly cause I would never ride it
motoguzznix Posted November 14, 2006 Posted November 14, 2006 luhbo said: This is true, but having the limiter at 9000 doesn't mean you'll have to use it. If I go to 8300 I also may want even more in some situation, why should I pass on that? Hubert According my calculations, the valve train is at the limit at 8500 rpm. A higher limit will soon cause damages - better to be safe than distroying the engine.
luhbo Posted November 14, 2006 Posted November 14, 2006 dlaing said: Beware the straw that broke the camel's back I'll bet if I set my throttle to never open past 50% and the RPMs to never go over 5000rpm my engine would last twice as long...mostly cause I would never ride it I'd be afraid my V11 would commit suicide one day if I'd use her like this. Probably those that went tits up over the last time and were never treated badly before did so. Hubert
Bill Hagan Posted February 10, 2007 Posted February 10, 2007 Well, mebbe's mine's not bigger. 78.2 max HP; 62.21 max torque Oh well, as long as Kathi doesn't find out. The dealer had an open house today to showcase the new 1098, and was running dyno for $25. As I'm selling the Ballabio (in a half-hearted way), thought I'd take advantage of the deal.
helicopterjim R.I.P. Posted February 10, 2007 Posted February 10, 2007 That is a lovely shaped graph for a touring bike. I can't wait 'til my friend gets her Norge (red, of course) so I can see how it feels!!
Bill Hagan Posted February 10, 2007 Posted February 10, 2007 helicopterjim said: That is a lovely shaped graph for a touring bike. I can't wait 'til my friend gets her Norge (red, of course) so I can see how it feels!! Hmmmmmm. I apologize for not being clear. Mebbe I should run the Norge for grins, but it was my Ballabio today.
helicopterjim R.I.P. Posted February 10, 2007 Posted February 10, 2007 A well sorted Ballabio at that!!
Paul Minnaert Posted February 11, 2007 Posted February 11, 2007 here a 1200sport on the dyno, gives 83 hp at the wheel. ( 90 at the crank) http://www.guzzisti.it/forum/phpBB2/viewtopic.php?t=19362
VA Sean Posted February 11, 2007 Posted February 11, 2007 Paul Minnaert said: here a 1200sport on the dyno, gives 83 hp at the wheel. ( 90 at the crank) http://www.guzzisti.it/forum/phpBB2/viewtopic.php?t=19362 Interesting to me that Bill's Ballabio (without too many mods) generates 78 rear wheel hp and the 1200 Sport is kicking out only 5 more. Bravo, Bill.
Pierre Posted February 11, 2007 Posted February 11, 2007 dlaing said: There wasn't one specific place, but I think there should be....if only for bragging With a little help from everyone who has dyno'd, this could be the place. Results circa '03. Cam, twin plug, CR increased. 91 RWHP 67 FPT http://www.guzzitech.com/Sporti-Dyno61003_PierreP.html Serious head work done since (mine and bike - sheesh), and new run will be made once clutch slip issue is sorted.
Guzzirider Posted February 11, 2007 Posted February 11, 2007 VA Sean said: Interesting to me that Bill's Ballabio (without too many mods) generates 78 rear wheel hp and the 1200 Sport is kicking out only 5 more. Bravo, Bill. Who knows which one generates more power? Unless they are dynoed at the same time on the same machine it is impossible to tell. I don't think it really matters- what is most important is how your bike feels to ride. Guy
dlaing Posted February 11, 2007 Author Posted February 11, 2007 VA Sean said: Interesting to me that Bill's Ballabio (without too many mods) generates 78 rear wheel hp and the 1200 Sport is kicking out only 5 more. Bravo, Bill. I thought that was surprising too. But as Guzzirider indicated, different dyno, different day. The 1200 supposedly has alot of potential for more power. 100 crank HP should be pretty easily obtained, especially on a friendly dyno. 100 RWHP could probably be obtained if you do all that Pierre has done to his bike. I can't wait to see his results ...and to actually see him ride the thing
