Ryland3210 Posted January 21, 2008 Posted January 21, 2008 This dyno run is on my '04 Le Mans, stock mapping, standard filter, Quat D Exhaust. In comparison to my '04, also with stock mapping, your AFR is a lot richer than mine above 4500 RPM (at least with the red graph). Mine is with the standard filter, but no airbox cover. I guess the airbox cover on yours could account for a richer mixture, but then your power is so much higher, so I'm confused by that. My silencers are Staintunes with no baffles, which help make my mixture lean. So the mystery to me is, how does your engine produce so much more power? My best guess is that the Quat D Exhaust must be a big improvement over stock exhaust and crossover with Staintunes. It also looks to me from your graph like my engine would produce a lot more power at your AFR of 12.9, instead of my 13.6 at peak horsepower RPM. I'd like to know more about the Quat D as well!
luhbo Posted January 21, 2008 Posted January 21, 2008 ...I'd like to know more about the Quat D as well! Sound is nice, look is great, top end is a mess, normaly! I'm keen on hearing more about it, yes. Hubert
dlaing Posted January 21, 2008 Author Posted January 21, 2008 It also looks to me from your graph like my engine would produce a lot more power at your AFR of 12.9, instead of my 13.6 at peak horsepower RPM. That seems to be the general experience. Maximum power seems occur around 13.0 ± ~0.5 I think Todd Eagan recommends 13.2 or 13.3 as a general target. Your 13.6 seems to be better than most stock bikes so John T. did not urge you to buy a PCIII. If you get a PCIII, John T. can optimize it for power at WOT. Not a bad idea since you don't spend enough time at WOT to be concerned about fuel consumption. Kind of an expensive way to gain just a few HP, but it is your choice.
dlaing Posted January 21, 2008 Author Posted January 21, 2008 Guz, these are interesting pictures! Both.The dyno curves, because they're looking so smooth and perfect and the one of the bike as well, because the exhaust seems to be something special, something between the first series with standard manifolds and the actual series with the outlet on the right side. Is the exhaust original or have you done any modifications? I'm using the actual Ex-box with catalyser, and it feels very much different to what your picture shows. I believe in this picture, no doubt, but it shows that there is probably a lot of room for improvements on mine. Do you have a picture of it taken from the other side? Hubert Hubert is your Quat D outlet on the left or right? Mine was on the left, but it was the early version for our bike and it certainly robbed high rpm power. I want Guz's muffler!!!
Paul Minnaert Posted January 21, 2008 Posted January 21, 2008 when I look at the graph from guz, it tells hdb mapping, so no default eprom in his bike there.
Guz Posted January 26, 2008 Posted January 26, 2008 when I look at the graph from guz, it tells hdb mapping, so no default eprom in his bike there. That's correct, the black/grey lines are standard and the orange/red lines the new HdeB mapping, What i like most is the max torque at 3500 rpm. The exhaust outlet is on the left side. I like the sound! But it is "slightly more " than standard. Guz
luhbo Posted January 26, 2008 Posted January 26, 2008 That's correct, the black/grey lines are standard and the orange/red lines the new HdeB mapping, What i like most is the max torque at 3500 rpm.The exhaust outlet is on the left side. I like the sound! But it is "slightly more " than standard. Guz I can see no difference between these curves, to be honest. The outlet cannot be seen on the picture, so it should be on the other side. That makes sense, yes. My only questions are: from where did you get this Exbox - this one is not sold by Quat-D, and how does the outlet look. Don't you have a picture of it? I'd greatly appreciate one, believe me Hubert
Guz Posted January 27, 2008 Posted January 27, 2008 I can see no difference between these curves, to be honest. The outlet cannot be seen on the picture, so it should be on the other side. That makes sense, yes. My only questions are: from where did you get this Exbox - this one is not sold by Quat-D, and how does the outlet look. Don't you have a picture of it? I'd greatly appreciate one, believe me Hubert Hubert, I got the exhaust from http://www.firestartergarage.it/ At this moment the block is repainted (black coating) so a recent picture will follow a.s.a.p. Guz
dlaing Posted January 28, 2008 Author Posted January 28, 2008 Hubert, I got the exhaust from http://www.firestartergarage.it/At this moment the block is repainted (black coating) so a recent picture will follow a.s.a.p. Guz Interesting. http://www.rossopuroitalia.it/index.asp?Pr...d_PrdType_ID=11 shows the QuatD with outlet on right side. Yours looks like it might be a one of a kind Quat-D!
Pascal Posted January 31, 2008 Posted January 31, 2008 Hello Here my Dyno results; 2001 Rosso Mandello with a PC III , Mistral carbon exhaust, Syucchi cross over, K&N air pods. http://www.twinzone.fr/V11/Dossiers/Powerco/powerco1.htm In blue the results after tuning of the PC III Here, some others results: http://www.twinzone.fr/V11/Power/power.htm Bye!
Francis Chartier Posted February 4, 2008 Posted February 4, 2008 Interesting.Yours looks like it might be a one of a kind Quat-D! I have the same QuatD on my 99 V11Sport, bought from Ghezzi-Brian in 2003 or 2004. The exhaust is on the left side. -- Francis Chartier
Ryland3210 Posted March 8, 2008 Posted March 8, 2008 Just bringing this up the thread stack. I read that Pierre may have an interesting dyno run to report soon.
dlaing Posted March 8, 2008 Author Posted March 8, 2008 I have the same QuatD on my 99 V11Sport, bought from Ghezzi-Brian in 2003 or 2004.The exhaust is on the left side. -- Francis Chartier Interesting. I wonder why they switched to the right side outlet. My earlier version QuatD exited on the left but had a slash cut outlet, rather than a bent elbow. It probably made power similar to Guz's below 5000 RPM, but above 5000RPM it lost power. You can see my dyno results in here http://www.v11lemans.com/forums/index.php?...ost&p=96629 and Guz's here http://www.v11lemans.com/forums/index.php?...st&p=136069 When it exits on the right side it seems to lose a little low end but make decent high end power....at least according to oldbutnotdead's post http://www.v11lemans.com/forums/index.php?...st&p=107871
dlaing Posted March 8, 2008 Author Posted March 8, 2008 Just bringing this up the thread stack. I read that Pierre may have an interesting dyno run to report soon. How many years have we been waiting for that report?
Pierre Posted March 8, 2008 Posted March 8, 2008 How many years have we been waiting for that report?Hey! I resemble that remark. Looks like last week in March before Louie's dyno schedule and my schedule line up. It would be easier if he were just down the street, but it's a couple hundred miles each way, give or take. Meanwhile, don't you have several pages of calculations regarding the flex, twist and compression properties of neoprene you can review while waiting?
