Ballacraine Posted August 27, 2006 Share Posted August 27, 2006 Info on this thread: http://www.v11lemans.com/forums/index.php?showtopic=7181 Unfortunately, it doesn't look like i took any pics of the V10 clutch before I installed it! Most awkward bit was having to change the clutch centre body. The mainshafts on the 5 and 6 speed units are a different diameter. The one off the V10 wouldn't fit & I had to source a twin plate clutch body from a V11. Nige. Link to comment Share on other sites More sharing options...
mark.gilmore Posted August 28, 2006 Share Posted August 28, 2006 Yep. It's already assembled, so it just needs to be bolted onto the crankshaft. The bolts were supplied with the clutch. It uses a special transmission input hub (also supplied) so that needs to be changed out as well. Yes I have just received a RAM cluch for my V11 Scura and will put it in next week, If all goes well. cheers Gilly Link to comment Share on other sites More sharing options...
stogieBill Posted August 28, 2006 Share Posted August 28, 2006 Yes I have just received a RAM cluch for my V11 Scura and will put it in next week, If all goes well. cheers Gilly Mark, Where did you get the RAM clutch from and how much was it? TIA, Bill Link to comment Share on other sites More sharing options...
mark.gilmore Posted August 30, 2006 Share Posted August 30, 2006 Mark, Where did you get the RAM clutch from and how much was it? TIA, Bill Hay Bill $1250AU at most Guzzi dealers, some want $1300.I think it will be worth it. Moto One was the Guzzi dealer I went through. cheers Link to comment Share on other sites More sharing options...
