guzzista Posted August 24, 2006 Posted August 24, 2006 If the temp sensor plastic housing cracks( all brass part available from MI and MG cycles in USA), A long 3/8 Drive 5/8 or 16mm 6 point socket will work to remove the brass part left in the cylinder head after the broken plastic part is completely removed... might have to raise or remove the fuel tank, though..thought I'd pass this along to those running into that problem. Cheers to all.
