dlaing Posted July 23, 2002 Posted July 23, 2002 Maybe a diet? Just kidding. arh! arh! I wish I could go fast enough to scrape. I scraped the stand only once and then shaved the rubber. But it is pretty clear that the front of the kickstand is next to touch and that if it does scrape it may catch on the road easily and cause an accident. Also I imagine that JimJib's kickstand switch does not work anymore, in which case he is probably best to unscrew the actuator as it is likely to catch on the road. But don't go driving off with the stand down!!! Or replace the actuator with a 5mm nylon screw, with the head cut off. The nylon should be safer to grind without catching, than steel.
Guest jimjib Posted July 23, 2002 Posted July 23, 2002 I think I will have a new bracket made to move the stand up a notch or two.
Guest hyper Posted July 23, 2002 Posted July 23, 2002 Jimjib, Now that I know you have a Scura ( nearly as nice as a rosso) it sheds new light on your problems. With your rear suspension being so stiff it would transfer more weight onto the front which will eat up your ground clearance. When you get your rear suspension done you will probably notice a totally different feeling from the front. When your at the suspension shop ask them to set up your sag front and rear as its a three person job. Tell us your impressions and your sag numbers. Thanks, Hyper
Guest jimjib Posted July 24, 2002 Posted July 24, 2002 What do you mean...nearly, hehe. I have a few frends that are suspension gods and they have been up and down this thing to no avail. I will post the numbers tomorrow...
Guest hyper Posted July 24, 2002 Posted July 24, 2002 Jimjib, Maybe wait until you try it for yourself to make sure its the real goods. Hyper
Guest jimjib Posted July 30, 2002 Posted July 30, 2002 Front with rider 49mm static 21mm Rear with rider 33mm static 8mm
Guest hyper Posted July 30, 2002 Posted July 30, 2002 You are using up approx. half your suspension travel just sitting on your bike. Whoever recomended this to you, don't give him your business. Give us the name of the shop so we can avoid it. Hyper
Guest hyper Posted July 30, 2002 Posted July 30, 2002 The rear numbers for the spring tension are good but the front is pathetic. I had to add this second response because I didn't elaborate in the first response.
Guest jimjib Posted July 30, 2002 Posted July 30, 2002 I made a mistake...its 38 not 48.. with rider. what do you recomend?
Guest Guest Posted July 31, 2002 Posted July 31, 2002 Hmmm, the first measurements did not look too bad. 28mm front and 25mm rear, if my math is correct...Is it the static sag that is bad? I am new to this sag thing, and have never measured a bike in my life, but that does not seem to be to far off.
Guest hyper Posted July 31, 2002 Posted July 31, 2002 For the last time, Sag should be between 30 to 35mm, bike only sag should be approx 10 to 15mm. There is some info on setting sag on this forum under "fork striction" and "suspension setting expierence". If this doesn't help email race tech . Go to their web site at www.racetech.com and you will find their email address and telephone number. Jimjib, get your buddies who are gods to tell them how to do it.
Guest jimjib Posted July 31, 2002 Posted July 31, 2002 Yes sir, right away sir...I will do it right now sir...may I be excused now sir.
dlaing Posted August 1, 2002 Posted August 1, 2002 I am soooo confused..... Front with rider 49mm static 21mm Rear with rider 33mm static 8mm That should mean that Jimjib is getting 28mm front sag and 25mm rear sag. (49 - 21 = 28mm and 33 - 8 = 25mm) Or do the 49 and 33 represent the sag that should be in the 30 - 35 range? In which case the 49mm of sag would be tooo much. Gods??? Hyper??? JimJib???
Guest jimjib Posted August 1, 2002 Posted August 1, 2002 The front with the rider on board is 38 not 48...I wrote it down wrong. The front adjusters are all the way to the stiff position.
Guest jimjib Posted August 1, 2002 Posted August 1, 2002 total sag with rider on board.....38 front....33 rear
