pShenk Posted September 15, 2006 Share Posted September 15, 2006 While installing the My15M, I noticed these wires (B1 and B2) and this connector (A). I don't see what they would be for, does anyone know? Link to comment Share on other sites More sharing options...
dlaing Posted September 15, 2006 Share Posted September 15, 2006 "A" is used to connect to the serial port on a computer, using TuneBoy, and probably TechnoResearch, or Axeone, but not PCIII. Not sure about the "B" lines. I seem to recall the B lines activate when the fuel pump is running, so it is likely for some sort of test. Link to comment Share on other sites More sharing options...
mark.gilmore Posted September 16, 2006 Share Posted September 16, 2006 While installing the My15M, I noticed these wires (B1 and B2) and this connector (A). I don't see what they would be for, does anyone know? Often wondered that myself. Link to comment Share on other sites More sharing options...
pShenk Posted September 17, 2006 Author Share Posted September 17, 2006 "A" is used to connect to the serial port on a computer, using TuneBoy, and probably TechnoResearch, or Axeone, but not PCIII. Not sure about the "B" lines. I seem to recall the B lines activate when the fuel pump is running, so it is likely for some sort of test. Thanks dlaing, that makes perfect sense (the test port). I'm still curious what the "B" wires are for, if anyone knows for sure. Link to comment Share on other sites More sharing options...
Murray Posted September 18, 2006 Share Posted September 18, 2006 The last of the carbed 1100 sports had a marelli digiplex ignition unit in which you could retard the timing two degrees by earthing a loose wire. Other than twin plugging I have no idea why thats useful maybe something similar it could also be an input for a oxy sensor as I understand some V11's had them and some didn't depending on the country it was delivered too. Link to comment Share on other sites More sharing options...
