pShenk Posted September 21, 2006 Posted September 21, 2006 this is a picture of the bung plug removed from my Stucci crossover. I also notice that the inside of my pipes are quite black... would this be an indication of fuel mixture problems? Or would it be about normal?
helicopterjim R.I.P. Posted September 21, 2006 Posted September 21, 2006 Put it back in your bung! Now!! I don't ever want to see it again!! It's not normal!! .... unless it's your exhaust pipe. Then it's not too far from normal. Relax ... then the bung will go in easily .... I hope.
dlaing Posted September 21, 2006 Posted September 21, 2006 Put it back in your bung! Now!! I don't ever want to see it again!! It's not normal!! .... unless it's your exhaust pipe. Then it's not too far from normal. Relax ... then the bung will go in easily .... I hope. I think your mistaking this thread for the other thread about variously colored rear ends..."Another point of view" FWIW black is normal and beautiful! If it was ashy white, or the outside is cherry red when hot, you should worry.
Guest Nogbad Posted September 21, 2006 Posted September 21, 2006 Where you have a mixture of gases containing CO and CO2, the proportion of CO in the mix is temperature dependent. The equilibrium equation is C + CO2 <----> 2CO. As temperature falls, the amount of CO2 relative to CO rises and carbon is precipitated out. As the exhaust gases hit the cold headers and crossover, they cool, the equlibrium shifts and carbon is precipitated on the cold surfaces. It's normal. That's what I mean......
quazi-moto Posted September 22, 2006 Posted September 22, 2006 Will he need the moly lube to re-insert his bung plug?
dlaing Posted September 22, 2006 Posted September 22, 2006 Will he need the moly lube to re-insert his bung plug? This thread needs ShockProof EXTRA Heavy
Guest Nogbad Posted September 22, 2006 Posted September 22, 2006 This thread needs ShockProof EXTRA Heavy What about this: Special Bung Lubricant
luhbo Posted September 22, 2006 Posted September 22, 2006 Man, what if my IE is traced? Could ruin my entire "He rides a Guzzi!" image.
pShenk Posted September 22, 2006 Author Posted September 22, 2006 See guys, that was just TOO easy. 100% handed to you on a plate Glad to hear the bung is normal though... I'll do another check up at 40.
dlaing Posted September 23, 2006 Posted September 23, 2006 Man, what if my IE is traced? Could ruin my entire "He rides a Guzzi!" image. Innuendo can sometimes help your riding image. Just keep the rubber side down!
