mznyc Posted October 7, 2006 Share Posted October 7, 2006 Hi Guys, I want to run in order of importance, Aux lights ala PIAA's Heated grips, Heated vest, Can I? What have you guys been able to run safely without maxing electr ical system? 02 Scura,with relays replaced. Thanks, Michael Link to comment Share on other sites More sharing options...
Tracey Posted October 7, 2006 Share Posted October 7, 2006 Gary speaks the truth... F.Y.I. I use heated grips and vest on a regular basis with no problems. My experiance has been that light added to the "drain" will kill the battery. A option I tried is LED driving lights, it worked. The LED driving lights help to be seen but not with seeing. = weak electrical systems... It's a Guzzi thing Link to comment Share on other sites More sharing options...
stobie Posted October 7, 2006 Share Posted October 7, 2006 I know some folks using these with success on dual-sport thumpers that see some rough terrain and don't have much juice to spare. MR11 HID SCMR16 HID These are bona-fide HID's with built-in ballasts. The first only draws 13 watts, the second draws 30. Being HID, they put out tons of light for the amount of power consumed. The only bugaboo is that they are polarity-sensitive, so if you hook them up backwards, you'll blow the ballast immediately, which is true for any HID. The black anodized ones would probably look okay (unobtrusive) on a V11. They're not very big. Not very expensive, either, especially to be HID. Look at me, planning accessories for a bike I don't even have yet! Link to comment Share on other sites More sharing options...
mznyc Posted October 11, 2006 Author Share Posted October 11, 2006 Hi Guys, I would be riding back roads,no stop'n'go city type traffic.so the revs will be above 3-4k most of the time.I also probably won't be riding below freezing,so I won't have the run the thermals very high,just to take the chill out of early mornings,after sunset situations.If I went the HID route you think I'll be OK? Thanks, Michael Link to comment Share on other sites More sharing options...
felix42o Posted October 11, 2006 Share Posted October 11, 2006 As soon as something goes wrong with my stock headlight...\ http://jwspeaker.stores.yahoo.net/himohe.html Link to comment Share on other sites More sharing options...
