Paul Minnaert Posted October 22, 2006 Share Posted October 22, 2006 For my MS injection, I have a sensor instead of a speedo cable, mounted in place of the cable on the gearbox. What I need to know is the ratio of the gears that are driving that. The one I can take out is 9 tooth, but does someone know the one in the gearbox that drives it? it's part 04762500, from the ones with the angle thing on it (first v11 le mans gearbox). I think I once have seen the ratio, as it's different on the bikes with the new style tacho. But I can't find it with the search. Link to comment Share on other sites More sharing options...
Alex-Corsa Posted October 23, 2006 Share Posted October 23, 2006 For my MS injection, I have a sensor instead of a speedo cable, mounted in place of the cable on the gearbox. What I need to know is the ratio of the gears that are driving that. The one I can take out is 9 tooth, but does someone know the one in the gearbox that drives it? it's part 04762500, from the ones with the angle thing on it (first v11 le mans gearbox). I think I once have seen the ratio, as it's different on the bikes with the new style tacho. But I can't find it with the search. All I have is these gearbox specs page, from the pictured V11 in manual , if that's OK for you GuzziGearbox_Specs.zip Link to comment Share on other sites More sharing options...
Ryland3210 Posted October 24, 2006 Share Posted October 24, 2006 All I have is these gearbox specs page, from the pictured V11 in manual , if that's OK for you GuzziGearbox_Specs.zip Does anyone know of a way to correct the speedo error on my 2004 Cafe Sport. It reads about 10 MPH high at 55. Link to comment Share on other sites More sharing options...
Alex-Corsa Posted October 24, 2006 Share Posted October 24, 2006 Does anyone know of a way to correct the speedo error on my 2004 Cafe Sport. It reads about 10 MPH high at 55. Perhaps you should take it to a shop that does calibration on speedos, and have it checked. Link to comment Share on other sites More sharing options...
