Karl Von Posted October 24, 2006 Share Posted October 24, 2006 Hi All I just picked up a 1100 Sport with a Daytona 1000 front fairing and need some replacement mirrors. For those of you that have the old sports & daytonas, what are you using for mirrios. I would like to find something that I would not have to redrill the fairing. I herd somewhere that there was a Nice Honda fairing mirror that bolted on direct with out having to redrill the fairing. Anyone know what it might be ? Thanks Link to comment Share on other sites More sharing options...
Alex-Corsa Posted October 24, 2006 Share Posted October 24, 2006 Hi All I just picked up a 1100 Sport with a Daytona 1000 front fairing and need some replacement mirrors. For those of you that have the old sports & daytonas, what are you using for mirrios. I would like to find something that I would not have to redrill the fairing. I herd somewhere that there was a Nice Honda fairing mirror that bolted on direct with out having to redrill the fairing. Anyone know what it might be ? Thanks I use the originals only , so I can't sugest any aftermarket,well ,actully I don't know if there are any euivealents for other marques. .Is it so hard to find the originals.? Link to comment Share on other sites More sharing options...
Karl Von Posted October 24, 2006 Author Share Posted October 24, 2006 Teo Lamers stocks them as well as moto mecca, They run about 80 dollars each. I have herd that they are not the best quality and are hard to keep tight. Have you had any problems with the stock ones ? Link to comment Share on other sites More sharing options...
Tom M Posted October 24, 2006 Share Posted October 24, 2006 Hi Karl, I don't know if this will help or not but Buell uses the exact same mirrors as the V11 Lemans, and they also have an extended version. Both are much less expensive than buying from Guzzi. I don't know if they could be mounted on a Daytona fairing but it might be worth looking into. Here's the Buell info: Buell part numbers for extended mirrors to fit V11 LeMans= N0161-2A8 (left side) N0162-2A8 (right side) About $20 each. Buell part number for standard V11 LeMans mirrors= N0161-02A8 (left side) N0162-02A8 (right side) About $25 each. Note the extra zero in the part number for the standard LM mirrors. That's the differentiator between the short and long versions. Link to comment Share on other sites More sharing options...
Hunter Posted October 24, 2006 Share Posted October 24, 2006 Hi All I just picked up a 1100 Sport with a Daytona 1000 front fairing and need some replacement mirrors. For those of you that have the old sports & daytonas, what are you using for mirrios. I would like to find something that I would not have to redrill the fairing. I herd somewhere that there was a Nice Honda fairing mirror that bolted on direct with out having to redrill the fairing. Anyone know what it might be ? Thanks Karl, I have mounted the mirrors of the Honda cbr-600, I think they are the same as the Honda SP-1 The sight is good, and they are more stabile as the standard. See picture! Best regards, Frans Link to comment Share on other sites More sharing options...
Karl Von Posted October 25, 2006 Author Share Posted October 25, 2006 Karl, I have mounted the mirrors of the Honda cbr-600, I think they are the same as the Honda SP-1 The sight is good, and they are more stabile as the standard. See picture! Best regards, Frans Thanks for the info Link to comment Share on other sites More sharing options...
Richard Posted November 4, 2006 Share Posted November 4, 2006 Thanks for the info If you are just looking for a set of mirrors that don't droop like the stock ones and only have a little better view, then the mirrors from the V11 Le Mans fit. If you remove the mirrors from the supports, file a little (and I mean a little) from the arm, then they fit into the original 1100 supports and look a damn sight better. The left hand one is the new mirror Old arm Le Mans mirror fitted into 1100 housing Link to comment Share on other sites More sharing options...
callison Posted November 4, 2006 Share Posted November 4, 2006 If you are just looking for a set of mirrors that don't droop like the stock ones and only have a little better view, then the mirrors from the V11 Le Mans fit. If you remove the mirrors from the supports, file a little (and I mean a little) from the arm, then they fit into the original 1100 supports and look a damn sight better. One of the best tips I've seen in years! Thanks Richard. Link to comment Share on other sites More sharing options...
Richard Posted November 5, 2006 Share Posted November 5, 2006 One of the best tips I've seen in years! Thanks Richard. I aim to please... Link to comment Share on other sites More sharing options...
