2002 tenni transmission
Guest ffatdad
I replaced the spring on the ratchet shaft in the transmission but now it will only shift into 1st & second
cant get it to shift to 3rd. It was shifting fine prior to the spring braking. Any ideas? I must have put something tpgether wrong in the trap door, help !!!!
thanks ,jim
thanks ,jim
I would guess you got the shift mechanism gears out of sync when you put it back together. I thought it was odd that in neutral, the marks didn't line up- you have to match the marks, then turn the gears to neutral.
This may help- this is the picture I took of mine before I took it apart to make sure I would get it back the right way.
Of course, this may not be your problem at all, but I think the 1, 2 shift used one gear, and third brings the other into play. If it was not lined up properly, it may create your problem.
Ryan
I suppose my craftsman tools in the background will start another tool thread...
