Lucky Phil Posted March 26, 2016 Posted March 26, 2016 Would it be possible to cut/chop out the old bushings and press a couple of spherical plain bearings in i wonder? Of course you can. Thats what my bike has effectively in the form of a Rossopuro unit. Ciao
stewgnu Posted March 27, 2016 Posted March 27, 2016 You could....and you would have a stiff arm linkage for this to work with / against . Think about that. So the cushioning effect of the OE arms bushings is necessary? I've got a rossopuro on my bike too and am just about to replace the rose joints for the first time. I did think that it's a lot of force slamming thru these rod ends on acceleration and braking- the bearing supplier I use mentioned that it may be possible to get 'racing spec' or heavy duty joints for more longevity. When the rod ends started to wear it manifested in the dreaded rear end 'clunking' sound as the bevel box rotated.
victor Posted March 27, 2016 Posted March 27, 2016 One of the forum member use this http://www.powerflex.co.uk/black-series/product-details/100+Series+Top-Hat+Bush/8517.html
victor Posted March 27, 2016 Posted March 27, 2016 I've found the topic http://www.v11lemans.com/forums/index.php?showtopic=17685&hl=bush&page=2
gstallons Posted March 27, 2016 Posted March 27, 2016 Yes , there needs to be cushion in this arm . A rigid link is not a good deal .
docc Posted March 27, 2016 Posted March 27, 2016 Yes , there needs to be cushion in this arm . A rigid link is not a good deal . The factory design does have *some* give, but with the rear drive off, the torque arm sticks straight out, self supporting. I've often wondered how much "damping" that creates in the rear suspension travel. Looks like the same discussion is going on on this thread in Technical Topics: http://www.v11lemans.com/forums/index.php?showtopic=17685&p=209958 I suppose we should pick one thread or the other to hash out our ideas and opinions on the effects of various methods of attaching the torque/reaction rod.
stewgnu Posted March 28, 2016 Posted March 28, 2016 Yes , there needs to be cushion in this arm . A rigid link is not a good deal . Would this be for easing strain on the bevel system/driveline? Or avoiding handling issues? I ask as I've not felt any detriment in handling since fitting the RP unit. Plus, why are all the aftermarket ones 'solid' links? As docc says- won't the suspension (and cush??) absorb shocks?
gstallons Posted March 29, 2016 Posted March 29, 2016 It is to lessen the strain on the driveline . And Docc's comment is true too.
docc Posted March 29, 2016 Posted March 29, 2016 It occurs to me that we could be talking of fore-and-aft rigidity, like Heim joints would provide, which is good, versus rotational rigidity which would resist the rise and fall of the suspension travel - which would be bad. I am presuming Heim joints and Rose joints are one and the same?
Lucky Phil Posted March 29, 2016 Posted March 29, 2016 It occurs to me that we could be talking of fore-and-aft rigidity, like Heim joints would provide, which is good, versus rotational rigidity which would resist the rise and fall of the suspension travel - which would be bad. I am presuming Heim joints and Rose joints are one and the same? Yes the same. As I pointed out in another thread it seems, no cushioning is necessary. The original design is what it is because its cheap to make, less machining. One machining operation and press fit some bushes. Cheap and cheerful. It has to be a hydrolastic bush only because its bolted up tight. The bush is there to allow the rear suspension to work not for shock absorption. A rod ended torque arm has zero end or side float and the anchor points at both the frame and Bevel box are cruise liner dimensions. So they are rugged. In case nobody has noticed Guzzi don't just over engineer everything they over engineer it then add some. That's why they weigh a ton. Ciao 1
stewgnu Posted March 29, 2016 Posted March 29, 2016 Its a pig of a job... I initially thought as i wrestled the wheel out, got filthy and whacked my grimy knuckles on the swingarm for the umpteenth time... Then, once I'd wiped down all the areas accessable with the rear wheel out, cleaned and checked the caliper, given the front shaft nipple a pump or three (sooo satisfying), greased the bevel needle bearing and shaft splines, looked at the torque rod- all clean with lovely new rod ends fitted... I thought: It was damn worth it.
cash1000 Posted August 9, 2016 Posted August 9, 2016 Hi Victor Have you got a source for the bush that has an English language website? I can't translate the website you gave from german to English. I didn't replace the original damaged bush and the 8.8 bolt is showing signs of wear. I until I sort replacement bush I've replaced with a new bolt.
cash1000 Posted August 23, 2016 Posted August 23, 2016 Has anybody replaced the bush with the item Victor recommends? I've found same bush at Gutsibits part no WHA88345 www.gutsibits.co.uk But they recommend it only for the CART Guzzi models. I've got them checking price and availability for the whole arm but don't expect it will be cheap! They have quoted 160 pound incl freight to NZ with a 8 week wait.
cash1000 Posted August 24, 2016 Posted August 24, 2016 Found a solution These people will take out old bush and make a new one for about $NZ50 www.autolign.co.nz Look under products/bushes/Nolathane Bushes: http://www.autolign.co.nz/catalogue/nolathane-bushes/index
Tom M Posted January 5, 2017 Posted January 5, 2017 I've seen the posts here about the reaction rod bushings deteriorating so I've been checking mine for slop a couple times a year. A few months ago I noticed that I could move the rod by hand a little so I think it's time for new bushings. Has anyone found replacement bushings that are available in the USA? The rod has to rotate at both ends as the swingarm moves up & down. Is it supposed to rotate on the bolts that secure it, or is the steel inner sleeve supposed to rotate inside the rubber bushing?
