NorBSATriGuzzi Posted December 14, 2006 Posted December 14, 2006 My "new" guzzi is running at 42 and 45psi F to R...seems high to me. I did not get an owners manual with it...what should they be?
slug Posted December 15, 2006 Posted December 15, 2006 My "new" guzzi is running at 42 and 45psi F to R...seems high to me. I did not get an owners manual with it...what should they be? Tire pressures from the manual: Front wheel: 1 up: 2,3 BAR (~34psi.); 2 up: 2,4 BAR (~35psi.); Rear wheel: 1 up: 2,5 BAR (~35psi.); 2 up: 2,6 BAR. (~37psi.); HTML Version of V11 Manual Circa 2000 (Thanks Callison!)
NorBSATriGuzzi Posted December 15, 2006 Author Posted December 15, 2006 Tire pressures from the manual: Front wheel: 1 up: 2,3 BAR (~34psi.); 2 up: 2,4 BAR (~35psi.); Rear wheel: 1 up: 2,5 BAR (~35psi.); 2 up: 2,6 BAR. (~37psi.); HTML Version of V11 Manual Circa 2000 (Thanks Callison!) Thanks!
antonio carroccio Posted December 15, 2006 Posted December 15, 2006 summer: 2.3 front---2.7rear winter (wet) 2.3 front---2.4/2.3 rear. Better grip with low speed.
Steve G. Posted December 15, 2006 Posted December 15, 2006 Some consideration should be made to the tires pressure readings on the tires you have. Tire pressures for pre '02 V11's are for Bridgstone BT57's, no longer available. Ciao, Steve
jihem Posted December 15, 2006 Posted December 15, 2006 i'm using Dunlop 207. front 2.5 rear 2.9 i got these figures from the Dunlop salesman himself.
mike wilson Posted December 15, 2006 Posted December 15, 2006 All supplied numbers are suggested starting points, based on assumed average loads and uses. The actual pressures that will work best for any given situation will vary (sometimes quite dramatically) from these unless it bears a close resemblance.
stormsedge Posted December 15, 2006 Posted December 15, 2006 Tire pressures from the manual: Front wheel: 1 up: 2,3 BAR (~34psi.); 2 up: 2,4 BAR (~35psi.); Rear wheel: 1 up: 2,5 BAR (~35psi.); 2 up: 2,6 BAR. (~37psi.); HTML Version of V11 Manual Circa 2000 (Thanks Callison!) When I had tires put on a year or so ago, I found they were inflated to 42psi. I have used various pressures from the 2 up recommended (as quoted from "Slug" above) up to 42, with no ill effect. Typically I inflate the tires a bit more on colder days. My bike is very sensitive to anything less than the 35/37 combination. k
docc Posted December 16, 2006 Posted December 16, 2006 A few years ago I experimented with higher pressures and harder tires to get more miles out of the rear. I learned that traction can be compromised and swingarms can get bent. Now I keep 33 in the front Diablo and prefer the Corse, and 37-39.5 in the rear ( the higher for greater load, hotter temperatures and higher sustained speeds), preferring the Strada. Tires and oil get changed at about the same interval.
