profWacko Posted January 2, 2007 Posted January 2, 2007 According to the owner's manual and the shop manual CD I have, the fork preload adjusters should have a range of 15 turns from min to max. Mine have only 5 turns before hitting a substantial stop. I have switched to heavier progressive forksprings from Wilbers and I need to add a little more preload since my sag measures 32mm/44mm (unladen/laden). Is there likely something wrong with the hardware on my forks, or does anyone else with one of these models really have 15 turns of preload adjustability? ADVthanksANCE -Jack
Mr. Bean Posted January 3, 2007 Posted January 3, 2007 Not sure, but I believe my Ballabio has the same non-Ohlins suspension as your LeMans. I can never remember which is preload, but the large, wrench-adjusted, setting does have a full 15 turns of adjustment. The little brass screw adjuster in the center only has about 5 or so turns lock to lock. Hope this helps, Randy
profWacko Posted January 3, 2007 Author Posted January 3, 2007 >>large, wrench-adjusted, setting Yep, that's the one. I guess I'll have to get mine apart again to see what's what in there. Thanks -Jack
