Convert a V11 LeMans
Guest DOUGDANGER
I have a 2004 V11 LeMans that I want to convert to a V11 sport or V11 naked. So I'am looking for the parts to do this. If not can some one point me in the right direction, how much to convert and parts need.
Thanks D :mg:
Only thing you need are the Sport Naked's headlight brackets and if you want, a bigger headlight.
Part# L.H. bracket: 0149 6240
Part# R.H. bracket: 0149 6140
You can also use aftermarket headlight brackets with fork clamps. Much cheaper and easier to obtain.
Good luck!
Any similar Bosch headlight will do- I used an item from a BMWR850R when I converted my Le Mans. Same size as the V11 unit.
Ducati Monster headlight is also the same size as the V11 Sport unit.
The V11 sport brackets are about £70 each new.
Guy :helmet:
Guest DOUGDANGER
Good luck!
Thanks Jaap
VA Sean will want to talk to you about a
final disposition of the estate of your lemans fairing.
He is on this site, if he has not contacted you yet...
Guest DOUGDANGER
Thanks
They are in probate right now
Doug :thumbsup:
Dang, looks like I missed another one. I'm in the market for one of those fairings, too . . .
Greg-
I know you are "next" in line.
I'll put you and Doug in contact with each other if he and I aren't able to work out something.
