number for gearbox clutch shaft main bearing?
Guest Nigelstephens
Got by box apart and the main bearing feels rough. :o
No bits in the oil and everything else seems okay.
Please would someone tell me a part number for skf or otherwise for the bearing I need to get. I know there has been alot about plastic cages and the like. Just want to make sure I donet get one of these. The gearbox is for an centauro 5 speed.
The bearing is the large one on the input shaft.
The selector drum moves around about 1mm laterally :huh2: with end cover on but no gasket. This does not seem that much but I have some shims coming. Has anyone got any experiance whether removing this clearance will actually improve gearchanges? I know Pete Roper has an article on this but just wondering if anyone else has done this job with good results.
If you can help me out with a pdf manual for the Centauro please PM me?
Thanks
Nigel
